I've got Linn Katan bookshelf speakers and Linn subs are pretty expensive so I was wondering if something like a HSU STF-1 would work well in a small room for music. I'm fine with the fact that a cheap sub will only play down to ~35Hz and I don't typically listen at very loud levels. But if cheap subs also come at the expense of distortion or are otherwise somehow "unmusical" I'll need to raise my budget a little.
Has anybody here had a positive experience with using a sub that was considerably cheaper than your main speakers?
