So I did the sub crawl this weekend with my Klipsch reference 10" sub and of course the best sound came from placing it right under my L front speaker. Since I have a built-in entertainment center, it is not feasible to leave the sub in that location and still stay married. I started building two ported jbl cs1214's end tables hoping it would even out the bass (see coffee table 2 pic) but when I moved the Klipsch to each of those 2 locations at the end of the couch, it sounded very boomy until I pulled it about 3 ft away from the wall, which again is less than ideal.
The Klipsch is rear ported so I turned it around a few times and it still sounded bad. Will a front ported or down ported design have less boominess if I place them in those same locations or are the bass waves so long that anything in those locations will be a compromise?
Options....
1. Build the 2 ported subs anyway and place them in locations #2 and #3 (Alt sub location pic) and hope they even out the bass?
2. Stuff a small front ported or sealed sub in the entertainment center (pic) and live with the fact that I may rattle it all loose and I will never see below 35hz?
3. Sell the jbls and build a massive 18in sealed sub to pressurize the whole room and not worry about location?
4. Other?
Room is a large rectangle open on the R side to the kitchen approx. 16x24x11ft ceilings and the couch is against the back wall...I know, I know it's my main living/movie room since I have no dedicated theater.
Thanks all!
Options....
4. Other?
Thanks all!
