1) Are two drivers in an enclosure of 4 cubic feet sonically the same as dual enclosures of 2 cubic feet with single drivers? Would this difference be the same for vented as well as sealed?
2) Can more than one driver, each receiving independent (and different) input signals, share the same enclosure space? If driver "A" models well in a 4 cubic foot enclosure, and driver "B" models well in a 3 cubic foot enclosure, can they share a 7 cubic foot enclosure? What about sharing vents and passive radiators?
3) If you can share a passive radiator with drivers receiving more than one input signal, how do you calculate which PR to use?
4) If you are planning on equalizing a sub, do you simply want to get as much SPL as low as possible and not worry about a flat response (knowing that you can correct for this later)?
