So this will be my first foray into the world of DIY subs, which has brought up a few questions before I get started.
I plan to build a matching pair into a set of end tables. As a result, these will be down-firing. I have not decided on ported vs sealed yet. I know that sealed will be easier to build, but I'm more than willing to make the attempt with a ported. This leads to a question. Given the size constraint of a reasonable end tabe, I figure I can do either a sealed/ported 15, or a sealed 18 (I think a ported 18 will just be too big). My space is approx 1,500 ft^3, but opens to another den area plus a kitchen. Total volume is probably somewhere around 4,000 ft^3.
It also appears as though there is not a ton of selection when it comes to actual speakers. My total budget for drivers/amp is around $1,000. Some that I am considering are the following:
Dayton Audio RSS390HO-4 15" Reference HO Subwoofer 4 Ohm
http://www.parts-express.com/pe/show...number=295-469
Dayton Audio TIT400C-4 15" Titanic Mk III Subwoofer 4 Ohm
http://www.parts-express.com/pe/show...number=295-420
I would consider something along the lines of the following if the performance jump justifies the cost jump:
TC Sounds Axis 15Q1 15" Quad VC Subwoofer
http://www.parts-express.com/pe/show...number=293-642
One of the SoundSplitter RL series:
http://www.soundsplinter.com/rlp15_s...formation.html
Also perhaps something from Ascendant, or AE.
I am open to just about anything at this point. I've heard that some work better for downfiring than others due to sag, so that needs to be kept in mind as well.
Any help will be appreciated!
