1 - 8 of 8 Posts
OK, I have bought (2) RTi8, (2) RTi6, and a CSi5 setup. It will be powered by an Onkyo NR626. The room is about 1700 cu. ft. I am considering the svs pb1000, the hsu stf2, and the hsu vtf mk2. O will watch 75% movies, 20% sports, and 10% classic rock. Which do you think will suit the room best. Max dollar allowed is 600 installed. Thanks for the help.
PB1000.
Or a PB12 NSD from the SVS outlet store., its 549.
Nashou
Originally Posted by nashou66  /t/1525228/sub-help-for-new-system#post_24553347
PB1000.
Nashou
It's probably hard to do better than this for $600 or less.
Discussion Starter · #5 ·
I am kind of leaning toward the VTF-2.4 since it is downfiring and I have kids that will be playing in there. Is there a real difference in sound between downfiring and out firing? Thanks for the suggestions!
Originally Posted by sndnichols  /t/1525228/sub-help-for-new-system#post_24554933
Downfiring can help mask harmonics and help reduce localization with higher crossover settings...other then that there is not a dig differencd between driver orientation on a subwoofere since frequencies below 100hz are omni-directional.
1 - 8 of 8 Posts
