1 - 4 of 4 Posts
I have an Acoustic Research AR S112PS sub that is only 4-5 years old. The sub was working great. I unplugged/stored the sub for a few months while I remodeld my basement and now that I'm finished and have plugged it back in I am having problems.
The sub puts out no sound whatsoever when fully plugged in, but when I pull the cable out so it is only slightly touching the connection it puts out a constant hum.
Anyone have any idea what the problem is and if it is worth seeing about getting fixed? Or am I going to need a new sub?
FWIW, I was looking into another sub to pair with it since my HT room is now enormous, but there is no way I can get two.
Discussion Starter · #3 ·
Was your sub working otherwise? I get no sound whatsoever from the sub, unless I plug/unplug the cable (Obviously, a big no-no).
When the sub is turned on and connected to the receiver, there is absolutely no response from it at all. I even checked the fuse, but it appeared to still be intact?
Any thoughts?
You said you had the sub in storage for a few months, in those months you might have changed some settings, did you try increasing the volume for the sub on the receiver/sub? I doubt your sub is the problem im thinking the problem is the receivers sub output or the sub cable, try a diffrent one.
Edit: if the sub has a switch on the back for selecting which input the signal is coming from select the input for your low level connection, ex. input 1=Low level
Input 2= High level. choose the one that corresponds with your connection.
1 - 4 of 4 Posts
