Emotiva XMC-2, Emotiva XPA-9 Gen3, JVC NX7, NHT VT-3/VC-3/VR-3, NHT iC4-ARC x4, HSU VTF-3 MK5 x2
The mains in my HT room are an older set of NHT VT-3s, which have two 10" powered subs in each tower. Because of room layout limitations, there's only about an 18" space between the left subs and the wall. Based on other comments that I've seen around the forums, its my impression that this close proximity to the wall shouldn't be a major concern for a sub, but I wanted to double check. Any issues or limitations that I should be aware of?
Part two of the question is that the right main/subs have no wall in similar proximity. In fact, the closest wall is about 12' to the right. Is the "imbalance" between the L/R wall proximities something I should be concerned about and/or trying to address?
