Hi, I'm about to receiver my sub, the SVS PCi20-39 tomorrow and need some setup tips. I'm using the Denon 2805 receiver with auto-EQ and currently don't have a SPL meter. I did a couple search for it and found the basic setups: set all other speakers to small, crossover to 80, compression off, and digital downmix off, etc.
What I'm not sure about is the setting on the onboard amp of the PCi20-39. I'm pretty sure I gotta turn off the crossover on it and uses the 2805's crossover. What should I do about the Phase and the Volume setting on the sub itself? I don't have a SPL meter yet, and I know I'll get one in the near future. The Auto-EQ is better than nothing right? What Volume and Phase setting should I have it on when using the Auto-EQ on the 2805?
This might sound kinda stupid, but is it safe to plug the sub into the outlet first and then connect RCA cable to the receivers Preout? Can someone give me a step by step instructions to setting up the SVS with a Denon 2805? Thanks for helping.
