Without investing more money into an EQ (I'm still getting flak on the dual Empire purchase), what would be the easiest way to assist in equalizing the sound for our listening environment? I use Audyssey that is built into the Onkyo 905 currently but for the life of me it I can't figure out why it's doing -15db to the sub after a calibration. It sounds very very subdued at this setting. (Both subs are at 11 o'clock) Should I by pass the Audyssey and run some REW's and equalize the sound myself with the the equalizer of the Onkyo? Problem with the Onkyo equalizer is it's only 7 points with 25, 40, 63, 100 and 160hz. Or is there a helluva lot more going on with Audyssey than that that I am not aware of?
I almost always exclusively use the THX ULTRA2 mode for watching movies. Do you know if Audyssey is bypassed in this mode in lieu of THX processing or does THX just post process Audyssey?
