Substitute for Yamaha RX-A830?
333 Views 8 Replies 4 Participants Last post by  Ahzroe1
Hi guys,
I've a Yamaha RX-A830, which will have 5 years old, it works well, but it didn't support 4K.
What are your suggestions to replace it? I want something around the same price (600€ at the time I bought it).
It will work with a PHILIPS 55PUS6703, an Apple TV 4K and 6 Cabasse speakers (MT222).
Thanks for your help.
Alex
1 - 9 of 9 Posts
@SpamsAlex what country are you in?
Do you want to stay with Yamaha?
Do you have plans to expand past 5.1 (why do you have 6 speakers or is one a sub)?
If you want to stay with Yamaha either the RX-A780 or A880 and A1080 if you need the full set of preamp outputs.
If you're looking to connect up to 9 speakers then the RX-A2080.
Hi,
Don't mind to stick to Yamaha.
Yes it's a 5.1 and I don't plan to extend it.
Alex
And I'm in France.
Thanks, the 2 last are too expensive, why I see how fast change the standard, I think I will keep it for 5 years, so don't think I will spend so much.
Well, if you're looking at saving money Costco has the TSR-7850 on sale and it is very similar to the RX-A780
Now that I see you're in France, this probably doesn't apply.
Hi,
I confirm doesn't apply for France :).
But Black Friday is coming, hope to find good opportunities.
Alex
I am not seeing the TSR-7850 on sale at Costco. Maybe expired?
1 - 9 of 9 Posts
