1 - 17 of 17 Posts
Discussion Starter #1 (Edited)
In the process of researching the clone amps I collected a bunch of links to tests and comments, many made by @notnyt, that took a bit of digging to find so I figured I'd post them up so maybe they will help someone else. The work he's done in the Measuring Amplifiers Thread to test these amps is awesome and really helps by having real power numbers so I wanted to mention that. This is by no means an exhaustive list just links to results for the most popular amps and some for fan mods and relay mod. If I missed something key post it up or send me a link and I'll add it.
The Clones
FP14000 Clones
FP2xQ - the big boys
XBS DS20Q and discussion - the DS designation sounds like dsp but I believe is the FP20KQ from them
XBS FP22000Q and test results
FAQ:
- when you see btaudio or smiths that is the same people, they changed their name. when 'enhanced' amps are discussed, it is the btaudio/smiths
- sinbosen and xbs are the same
INukes aka the Berrys
Other Amps
More Amp Related Stuff
Non-Amp But Sub Related Stuff
Thanks for consolidating this. Should be a sticky.
@notnyt Did you ever put the PL236 on the bench for testing? I saw photos but didnt see any testing info. Ive got one and Im curious on what its actually putting out. My guess is about half the advertised 1800w/ch @ 2ohms.
@FOHTech,
I also own three of the QSC PL236 amps and would be VERY interested in seeing the testing results if notnyt already has them. How well do you like yours and what are you using them on?
Dave
Are there any good alternatives to the Behringer NX1000DSPs (for similar pricing)? I'm not happy with it's measured performance, but I can't find any real alternative, especially with an integrated DSP. I willing to DIY if I have to.
With both channels driven, it'll sustain about 2400w for a bit. Not much burst. Single channel 1800w, no burst over that.
https://www.avsforum.com/forum/155-diy-speakers-subs/1780914-measuring-amplifiers-10.html#post44874081
There's the 3k and the 6k.... they're pretty good on dollars/watts, don't find much cheaper with acceptable DSP.
1 - 17 of 17 Posts
