For the OP @ac2bIf you like the sub, it might not be hard to simply convert it to passive with an outboard amplifier. Check my signature for a “how to” article.”
Wayne A. Pflughaupt
I did try this but no luck. I also found that sub on Amazon, was hoping to just get the board for cheaper but no luck on that.https://www.amazon.com/Pinnacle-PS-...=2025&creative=165953&creativeASIN=B0015AB7U6
Try plugging into a different wall outlet.
Thanks i will look into this. I had a passive sub before in some cheap 5.1 system, and it sucked. Was quiet and might as well not even been there imo. Would that be the case with this sub? It is considerably better than that pos thing i had like 20 years ago.If you like the sub, it might not be hard to simply convert it to passive with an outboard amplifier. Check my signature for a “how to†article.â€
Wayne A. Pflughaupt
Thanks. I checked out your site the other poster linked and sadly my sub doesn't have speaker wire connections, so either way i gotta buy something. Thanks for the helpI think the operative words there are “cheap system,†not the fact that the sub was passive. I mean, most earth-shattering DIY subs are passive. At the PS225’️s price range it probably didn’️t have any on-board processing except limiting, so with a comparably powered outboard amplifier it will sound as good as it did originally. The PS225’️s amp was rated at 225 watts, which is probably generous as there are no further qualifiers. Who knows, that might have been a peak figure at 15% distortion. I expect a good 150-watt amp would work fine, or worse case 200 watts. Find something used on Craigslist, ebay or a pawn shop and you'll get this thing up and running again for less than the price it would cost to replace it.
Wayne A. Pflughaupt
Awesome. 1 more question, do i need a separate external amp or will my receiver do the job? It's a Denon avrx 2400h. Would i do a left and right channel? Which speaker output would be good to use?You can install your own speaker terminals. It’️s a piece of cake – all you need is a drill. There’️s probably a blank section on the back panel somewhere.
https://www.parts-express.com/dayton-audio-bpa-38g-hd-binding-post-banana-jack-pair-gold--091-1245
Wayne A. Pflughaupt
