1601 - 1620 of 1930 Posts
It's still the same amount of ULF on the disk....So no BEQ doesn't increase the amount of ULF but it does increase the depth/extension of the ULF on the disk. So the percentage is the same.
The BEQ conversation increasingly seems like a tomato/tomahto discussion to me, since people are using the term "more ULF" in different ways. Perhaps it helps a bit to frame the discussion in the following way. It is very hard to hear frequencies below about 20Hz, in conjunction with other bass sounds, until the volume of the ULF sounds approaches about 100Hz. That number probably varies depending on the noise floor of the room, the overall volume level, the specific hearing of the individual, etc. But, 100db is a pretty good number to use for discussion purposes.
BEQ doesn't create ULF that never existed in a soundtrack to start with, but it also doesn't simply increase the loudness of that ULF content. In many cases, it may change the ULF from non-existent, by reason of inaudibility, to perceptible, thereby enhancing the overall special effects. So, it doesn't add to the overall percentage of ULF in a movie, but it may absolutely add to the overall audibility of ULF in a movie.
Just thought I would throw that distinction out there, for what it's worth. :)
Mike
Edit: There is something else that I think may be worth noting. People who are already implementing a significant low-bass house curve may be doing the equivalent of Bass EQ for all of their movies. If they are lifting their
Did you mean 21" by chance? Rythmik has half a dozen 12" models already, probably the most of any company.
It must be Seaton coming out with the 12" models then. Just goes to show how many new options we will have soon to choose from , from a 21" Rythmik , a 12" Seaton , possibly dual 10" from PSA and a mystery 'Big" sub. Plus all of the great choices we currently have!
So if there was 5% ULF content on the disk before BEQ, then there still is 5% after BEQ. The 5% range has been altered to extend deeper is all.
This distinction doesn't make any sense. beq changes the spectral balance of the track so there is literally more "useable" ulf
i.e. in this example, previously there was basically 0% of the track with useable ulf (content that you can hear or feel) and now there is 5% (the scenes which had rolled off content on disc) of the track.
21” Rythmik? Never heard any mention of that anywhere.
Discussion Starter #1,606
I recently experimented with this on Art Sonneborn's Trinnov. This was instigated from Art being a big fan of NASA movies and documentaries, and as many know, First Man was pretty much castrated in the lowest frequencies. I saw the posted info on the BEQ thread, and found I could implement some curves with the PEQ already available in the Trinnov using different presets. First Man really is a worst case example. We listened first with the typical system setup, and then engaged the boost which was very significant below 35-40Hz. While I ultimately dialed back the boost 3-5dB from what was suggested on the thread, it instantly transformed the launch sequences, especially where they were getting set and buttoned up in the pod. Without BEQ it was anemic and sounded like a TV recording, while the bass boost suddenly made all of the VLF punctuation of footsteps walking through different spaces, doors closing and rumblings in the background. As recorded on the BluRay these effects were so far down from audibility that for practical purposes, it was bringing back content previously not realizable.
I would point out that the vast majority of the EQ curves are MUCH steeper than any house curve. As anyone who's been around while I'm calibrating has witnessed, I'm pretty quick to audibly identify what I like as a good balance in a system of the content below 25Hz vs above. Too much below 25Hz or even in the 25-45Hz range will quickly muddy the detail and sound un-natural, and usually benefits more from overall more level vs added tilt to the response. It was plainly obvious in listening when the gain was in the ballpark of bringing the VLF content up to appropriate levels corresponding to the rest of the range. I ended up leaving 3 BEQ settings in separate presets to hit some curves I found more typical, with corners roughly around 20Hz, 30Hz, and 40Hz (for First Man). I do think the recommended filters are rather inefficient vs 1-3 shelf filters and 1-2 correctly set PEQs, but the net effect is impressive, beneficial, and plenty safe for a film that's been analyzed and with subwoofers that have appropriate protections in case you accidentally send a signal 10-30dB past the comfortable limits.
Hi Mark, thanks for sharing, do you by any chance recall the exact freq, db, and Q values you used as I would love to compare to the one we have on the BEQ thread
  • Like
Reactions: SuperFist
Writer & Reviewer
Mark does indeed have the JS12. I didn't recall Brian mentioning he had a 21" driver in the works, but you never know anymore.
Discussion Starter #1,608
I have not heard any mention at all about a 21 inch. I think he would likely get a G28 and FV28 done first before he ever thought about a 21 inch
Premium Member
Have you looked at the BEQ thread ba? I just glanced at a few and there is substantial output down to 10 hz and some in the single digits on the few that I saw. And these aren't "bass" movies either. Avengers sloped off pretty heavily before BEQ. Here's Atomic Blonde too.
Sure have although I don't frequent it since I do just as Mike is describing below VVVV
My post got all screwed up , I dont know who is making what or if ANYONE is making a new 21" sub...lol....Seems like we are on the forefront of an arms race of subs between ID brands!!
More useable ULF in the areas where Low Frequency content is already encoded. It doesn't transform the entire sound track.
First Man for example is extremely neutered in LF content. BEQ helps this sound track a lot, but it's still just adding more low frequency content to specific scenes. It's not like you are going to turn on BEQ and the movie suddenly has ULF start to finish. The same areas of the sound track that had bass pre BEQ will now have more presence and weight post BEQ.
I have had Anti-mode dual core and Mini DSP devices in the past. I use to play with house curves and low shelf filters. I found that most tracks sound the best left alone or slightly boosted(+3db) house curve or it sounds artificial and muddy. Just because the graph looks better doesn't mean it will actually sound better. Some rooms sound better by not significantly boosting low frequencies due to room resonances and vibrations.
Fwiw I am not implying BEQ is not worthwhile. I think it's a great supplement to gain useable extension with all of these filtered movies...especially for those with the right rooms to do it.
The issue with First Man is there was almost NO low frequency effects anywhere in the soundtrack, and the recording analysis confirms that. This difference is more akin to listening on a system with vented sub that dives off a cliff at 35Hz to a large array of sealed woofers with
Premium Member
It was slightly un-nerving to apply the filters, even knowing how well my own subs are protected, but looking multiple times at the measured soundtrack content and a first listen eventually put me at ease with it.
I about lost my lunch the first time I saw the amount of LT boosting that was taking place on a few of the very first BEQ's. To the point I almost somehow smelled burning voicecoils just sitting there at my work desk. :) Bosso probably WOULD lose it looking at some of those filter layerings.
Im the wierdo here.. I do not use BEQ and probably will never.. but maybe because I am mainly a music dude.
seems like talking at cross purposes here as this is what I wrote above, probably it's just semantics (of transform or amount) though as a filter does literally transform the entire track (aka waveform), I mean that's what a filter does :)
Discussion Starter #1,617
This conversation started as I made a comment here that with BEQ there was more ULF content available. I still believe that statement is true as many movies had below 20hz content that had been filtered out and BEQ is unlocking it. Now how that statement is spun or interpreted is up to the individual. The fact that BEQ helps with filtered movies is a fact.
Premium Member
Sure! The discussion was, assuming 5% of the LFE track is below 20hz, Using BEQ doesn't change that, it just enhances that 5%. Use the Hulk cop car smash as an example and for a second let's pretend it has a similar rolloff to the MCU movies. When that 5hz note hits you wont get that floor wobble effect if the track had have been filtered, BUT the sound effect was still embedded in the audio track, IT WAS STILL THERE. Then you apply BEQ to drag that effect up into the range that you will actually experience the effect. The point it, the sound effect had to be there in the first place for BEQ to find it. The semantics argument could be that my statement that only 5% of a soundtrack is below 20hz is meaning anything and everything encoded to the soundtrack below 20hz regardless of level. Your system may only be able to play 50% of that 5%. OR the movie is filtered so you are only able to really experience 50% of that 5%, doesn't matter, it's still there and only 5% of the soundtrack. Now in the latter example you can use BEQ to now experience 100% of the 5%.
Stick a fork in this convo, it's done :D :D :D
And there is a thread for those of us who appreciate what Beq brings. After spending $$$$ on subs, some with MAs/Boss, to get the extension down to 20hz or even to a single digit hz, it is up to an individual to decide playing 20 or higher hz filtered contents on his/her system. I know that I play my subs to their fullest potential making my investment worthwhile ;)
