1 - 6 of 6 Posts
Morning All! I just picked up a Marantz NR1605 Receiver and the Definitive Technology ProCinema 600 speaker set. Last night I got the fronts, center, and surrounds all nicely hooked up and was about to work on the subwoofer when I realized a problem. The subwoofer output on my receiver is RCA and the inputs on my sub are standard speaker inputs. Am I **** out of luck and need to return the speakers?
I see a LFE RCA jack right below
The crossover knob. Use that.
What sub are you using? Does it have a LFE input. Connect sub pre out to LFE on sub with single rca cable.
If by "smart" you mean we can read (manuals in particular)...then, yeah. :D
  • Like
Reactions: dmb12679
1 - 6 of 6 Posts
