Status
Not open for further replies.
1 - 5 of 5 Posts
Mike,
Mine is in the same position and I face it away from the wall toward the back of the TV. I think you would find it to "boomy" if you faced it to the corner but who knows you may want to try it.
jack
From all of my experience with subwoofer placement, front firing the active driver usually gives the best results. However, it is also important to consider where to place the subwoofer. To find the best location for the sub, do this test: place the sub right on your listening position, play a cd with lots of bass ranging from the lowest to the highest bass notes. Walk around the room and find the spot where it sounds the best. once you have found the spot, locate the subwoofer there and enjoy. This is the best location for the subwoofer.
James
Since your wife does not allow anymore placements other than the corner, try all of the placements, towards the left, straight at the TV, or firing along the right wall and see what sounds best to you. I don't think firing towards the corner will produce good results but its worth a try.
James
1 - 5 of 5 Posts
Status
