Hi All,
I have been trying to go through the subwoofer distance tweak over the last few days, but I am not making any progress... if anything, graphs look worse.
My Equipment:
Pioneer SC-1523-K AVR
FL/C/FR - Polk RTi8/CSi6
SL/SR - Polk Monitor 30
Sub - Testing 3 different subs.
1 - PSA XS15se
2 - SVS PB-1000 (might up this to the 2000)
3 - Polk PSW505 (original)
I have a pretty wide null in 60hz-80hz range, no matter which sub I use.
Is this the correct way to do the distance tweak? I am only using 1 sub at a time.
1. Disable EQ and SWAVE on the AVR.
2. In REW set all speakers to 75db.
3. Take measurements
a. Front Left - by itself. Unplug the other speakers.
b. Center - by itself. Unplug the other speakers.
c. Front Right - by itself. Unplug the other speakers.
d. Sub - by itself. Unplug the other speakers.
4. In the AVR setup, change the SW distance 1' at a time.
5. Measure the SW alone, again.
6. Keep making changes until there are no nulls or peaks.
This is what I have already tried, but maybe I am missing something.
The MLP and the R/L/C can't be moved. I'm trying to avoid using any external EQ.
Any help or advice would be great.
My Equipment:
1 - PSA XS15se
