Hi,
About four years I purchased a Velodyne SPL-1000 sub. Unfortunately, the sub often starts to distort very heavily to the point where it must be turned off for some time.
The distortion sounds like white noise with lots of base naturally. I posted some years ago about the problem but really did not find any good answers other than talk to support which told me to replace the amp.
So Velodyne replaced the amp twice in the first year or so but the problem really never got fixed. I got tired of sending it in for replacements without any tangible change or success.
I am wondering what could be causing this? The sub is by no means overused or is required to do any heavy lifting. It will most often distort light jazz that plays in the background while we have people over at very moderate volumes. Strangely, during movies where the base is actually required to perform it does not seem to give out, it seems.
I can live with the fact that the sub woofer has issues as we are rarely using it these days. Once it distorts, we turn it off and it simply stays in this position until I think to turn it back on which is rarer and rarer. Kind of sad though for a $1000 sub.
The issue occurred with a Yamaha HTR5890 and still happens now with a Onkyo TX-SR606 which replaced the Yamaha about a year ago.
When it works, this sub is awesome for my purposes and sound expectations. I just which it would actually work consistently. For the most part, it's been an expensive paper weight except it sits below our TV so I can't use it as such either.
Is this a known issue? What could be the cause? What's is a good replacement for the Velodyne SPL-1000? I need a small sub (not much bigger than the SPL-1000).
