1 - 4 of 4 Posts
Debating on which subwoofer to mate with my Def Tech BP9060 towers, CS9060 Center, DI 6.5 LCR's, DI 5.5BPS Surrounds. Running on Yamaha 3070 receiver. Room is 17 X 21 X 9 dedicated room. Would like to spend about $500-750 per sub (going dual). Would be willing to spend $1000 each if consensus is that would be the way to go. Looking at SVS, HSU, Rythmik, Outlaw, or similar.
Would prefer low extension below 20. 80% Movies, 20% Music. Thoughts appreciated. Thanks!
There really isn't a bad choice with HSU,SVS,Rhytmik or PSA. On the more budget friendly side, The SVS PB-12 NSD are currently going for $500 each. If you want kick in the chest effects with plenty of output, dual HSU VTF-3 MK5's are reasonably priced and would be more than sufficient in that size room.
That’s a big room. Go dual Hsu VTF-3 MK5 for a little over $1,700 delivered and with the right placement and settings they would rock!!!
BP8080’s with VTF3.5
Discussion Starter · #4 ·
Thanks for the feedback guys. Was leaning toward the VTF3 MK5 but wasn't sure if it would be overkill. On the same note, wasn't sure if the VTF2/PB200 would leave me wanting more.
1 - 4 of 4 Posts
