I am going to run 6 UM18-22's in my new theater off of 3 inuke 6000 amps. Would it be better to run nu6000dsp's or the non-dsp's and use a minidsp 4x10HD? It's a few hundred more to go with the minidsp, but if it gains me a lot it is well worth it..
I am thinking of just throwing out sanity completely and going all large ported enclosures instead of small sealed. Which option would be best for protecting the woofers in this case? The inuke doesn't have a subsonic filter below 20hz, but then I have never simultaneously tried to get sub-20hz bass while protecting a woofer below the tuned frequency of the enclosure. I never played with the protection on the inuke in my last theater, so I am unsure the best way to play this out... Is current limiting better than a subsonic filter in a situation like this? And can the minidsp do a lower subsonic filter?
As for placement, I am a bit undecided. I will probably go 2 in the back and 4 in the front (27'x17'x9' room). Unless someone has a very compelling argument for subs anywhere other than in front and/or behind, I am hesitant to upset the aesthetics of the room with mid-room subwoofer enclosures. Hard to hide an 18" sub with a large ported enclosure in a column...
I will be running all balanced pre/pro and amps. This is another area I am fuzzy on - the minidsp says it can run balanced or unbalanced, so does that mean I have to wire my own XLR's to the terminal blocks on the back of the unit? I can't see a good pic on their website and I have never used the minidsp products, so I am just guessing... There is only one XLR output in the pic, so how do you get 10 channels of balanced output?
Is the minidsp the best option for multiple subs? Does it play well with Dirac Live on the pre/pro?
Any other advice here? The only thing I already have are the subs, the rest is still up in the air. (Well, I have the pre/pro and amps for the mains, surrounds, and atmos already, and I am pretty dead set on Titan LX's and Volt 10's for those speakers too, but the bass is still up in the air)
