1 - 3 of 3 Posts
I just joined at the suggestion of a friend who thought someone might help me solve a problem I'm having with my subwoofer, a Paradigm PS1000. I am trying to reconnect it to a SONY DA777ES. It worked fine at my old home, now nothing. The supplied cord has a single plug on each end. I have it plugged into Low Level Input in the sub, and into Pre Out in the Sony. When I adjust the SubWoofer Level anywhere above MIN, I get significant hum. I also don't think I'm getting any output. Any guidance would be most appreciated.
Paul
Don't use the preout output, use the subwoofer output.
second that!!! otherwise you'll be sending it a full frequency signal.
1 - 3 of 3 Posts
