subwoofer hum
393 Views 4 Replies 2 Participants Last post by  rjg08
I have searched these threads and still at a loss to why my sub is humming all of a sudden.  Here's the story.  I have a Denon AVR487 receiver and sub-woofer.  I wanted to control the volume of my indoor speakers when I had the outside speakers on so I installed an audio switch from radio shack.  It turns off my surround speakers so its not too loud inside when I have it on outside.  Once I did this and not sure if this is coincidence or not my sub hums now really loud.  I have tried a new cable, removed the switch, plugged the power into a separate circuit and it still hums.  I talked to Denon and they sent me a Boston Acoustics sub, tried that and it still hums.  I am dumbfounded why this is making this humming all of a sudden.  I even unplugged all the speakers from the receiver and it still hums.  This may help; I unplugged the sub cable from the receiver and the hum stops but if I touch the end of the plug it makes the hum noise.  Any help would be greatly appreciated.  Thanks.
1 - 5 of 5 Posts
You probably have a ground loop. Why now and not before who knows, but you must have changed something in the system. You need to transformer isolate the signal between the AVR and sub with something like this:
http://www.amazon.com/Stinger-SGN20-Ground-Loop-Isolator/dp/B002ZRQ3PW/ref=pd_sim_auto_4
This ground loop isolator has two feeds where my sub cable has one, do you just use one red connect thru or black one?  or am I missing something here.  Thanks for your help by the way.
Use either one. There may be some made specifically for subs that have only one transformer.
I just got the ground loop isolator and it worked, thanks for the advice!!!
1 - 5 of 5 Posts
