Hi all,
I have a pretty old Acoustic Research AR 500 15 inch down firing subwoofer. Recently it's been acting a little strange. It's connected to my Onk 705 receiver via coax cable.
Lately when I power up my stuff the subwoofer would emit a low level pop, then go into standby mode. every once in a while it would turn back on again, as if it was receiving a signal, then shut down.
I've checked all the cables, and everything is tight. the receiver shows that the subwoofer is connected, but when i use the 'test signal' function, the subwoofer is present, but does not have sound.
how can i tell if it's the receiver that's messed up, or the subwoofer? is there a way i can test?
thanks in advance!
thanks in advance!
