Hi guys, finally set my system up in my living room. It sounds great but am noticing a terrible unequal distribution of sound for the subwoofer.
Im running a denon e300 to power 2 klipsch rb-61 and premier acoustic pa 150.
I have the sub on a subdude to reduce vibrations between the sub and wood floor.
My problem is simple. Some areas of my living room are bass heavy, others are non existent. About 25 ft away in the third bedroom I can feel the bass better than while sitting in the living room. Im not sure what to do. It is corner loaded because thats the only place it will fit and like i said its on the subdude.
I ran audyssey on the denon and adjusted the source input gain and woofer gain. I'm a novice at all this, how do i equalize the distribution of bass in my living room?
