1 - 3 of 3 Posts
Hi, here is a picture of my room:
http://www.facebook.com/photo.php?pi...0d&id=29409598
I am wondering if I should put the sub along the wall in the right hand side or if I should bring it out, (so its not flush with the tv/tower speakers wall)
I haven't bought it yet, but I wanted to know if I should move my TV up to 6in to the left and keep the sub flush or not. The sub is 18" wide that I will buy, I have a total of 2'-2" between the tower and the wall, and I have only 6" between the tv and tower speaker on the right. How much room do I want between the tower speaker and sub and tv? and how much between sub and wall? Is it better to keep it in the corner or can I move it forward?
I have an extra tower speaker, that I will use as a center, that I will build a shelf for and I want to level it with the TV (that's why i have tape marking the studs:p), so I want to know if I should move the TV a bit over, or if 3" between speaker,sub, wall is good/bad?
I think you guys know what i'm asking:p
- how do you plan on putting a tower speaker over the tv? laying it on it's side is not going to be a good idea...
- you really need to get those speakers centered on the tv... i'd move the tv over...
- as far as the sub goes, it would be guessing at this point... hook it up and push it around... it will tell you where it wants to go....
AJ
If there's any way possible, think about having more than one sub--two at a minimum. You will be amazed at the difference.
http://www.harman.com/EN-US/OurCompa...s/multsubs.pdf
Many on this forum have read this and implemented it, and it makes an amazing difference. Some of us have been to the Harman International/JBL labs in Northridge, CA and seen the theory in action. It's simply amazing.
1 - 3 of 3 Posts
