Originally Posted by capecodorthopod /forum/post/20865931
The Epik Legend fits the OP's frequency response requirements. It's available in Europe from L-Sound, but I don't know if it goes slightly over budget with the recent drop in the dollar.
The OP's criteria are difficult to match. Good extension, strong midbass, low price and available in Europe. The Legend meets all these with outstanding sound quality to boot.
Jesse I think he means anechoic specs. Although not every manufacturer is honest on specs (ie Def Tech).
If the Legend has a similar response to the Empire, it only meets that spec (at 2M GP) if crossed at 80hz per Ricci's testing. Crossing it higher and you've got a significant roll off of 9db IIRC from 80hz to 20.
Regardless, the 20hz to 120hz at -3db is more or less meaningless without knowing the room size, distance to LP, at what level the OP expects to achieve that, etc.
If the room is 1000 cubic feet, that may not be that difficult to achieve, if it's 4,000 cubic feet, he may be able to get that spec at 75db if he's lucky, etc. If the room is small, he may be better off going with a sealed sub to take better advantage of room gain, if larger, a ported sub may be more appropriate.
I don't think HSU can ship to Europe and give him a sub at $550 or under, so that is out of the question I would guess (otherwise I'd say look at the VTF-2 for $509 + shipping).
Having said that, he says "Europe" and under 550 bugs. Not sure if that is UK Pounds or Euros, or US dollars.
Something like this may do the trick, was well reviewed by Ilkka IIRC. 495 Euros or so.
http://www.bkelec.com/hifi/Sub_Woofers/monolith-df.htm
