Subwoofer to pair with powered speakers.
436 Views 16 Replies 4 Participants Last post by  basshead81
Hi, I don't really know anything about subwoofers, but I listen to and produce a lot of bass oriented music and my speakers aren't cutting it anymore... There are all sorts of sounds that don't even appear out of them... I have the Kanto YUMIs and I think they go down to 60Hz... I want to go down to at least 10Hz.
What woofer would you suggest for ~$300 (a bit more or less if you think the quality is significant)?
1 - 17 of 17 Posts
You have two goals that don't match....10 Hz, and $300, you can't really get both.
Having said that, under $500, I would look at the offerings from HSU Research.  At $500, a top pick is the SVS PB or SB1000, depending on room size and if you want it to work well for movies along with music.  PB1000 will have much higher output around 20Hz, SB will extend lower in a small room but have substantially less output around 20Hz.
By the way, there  is very little content in most music below 40 Hz.
  • Like
Reactions: 1
I am aware of that, but I produce bass-oriented dance music for systems that go extremely low (~10Hz) and need to have those frequencies accurately represented.
It looks like I will have to save up a little bit :) Are these under $500 options worth going for or in your opinion is it worth spending a little extra money?
Also, the room they will be in is relatively large and long, think three small rooms put together in a row... is the PB1000 a better option?
Originally Posted by bear123  /t/1517369/subwoofer-to-pair-with-powered-speakers#post_24345421
I agree with bear's thoughts. Personally I would look at the $500 options if you can pull it off, if you can't I would wait and save until you can.
In a large room, you can't get 10Hz for $500.  Realistically, you will only get 10Hz with a sealed sub in a small room.  Without spending a lot of money, you wont get 10Hz, which is something you will only feel at high SPL's, but not hear of course.
If DIY is an option, a powerful sealed sub would get you some 10Hz output, maybe.
  • Like
Reactions: 1
If your room is as large as you say you will realistically have to up your budget or reduce your expectations. It's just the reality of bass and subwoofers.
DIY is definitely an option and desired if it can get me the results I desire for less $$$.
When you say DIY, what exactly do you mean? I'm guessing, I need to build a good box and find a suitable driver? Will this require extra amplification?
If this is the case, what options am I looking at? This is something I'm willing to take some extra time to save up for...
I would suggest you hop over to the DIY forums.  Don't know where to guide you other than that as I am not familiar with those forums, maybe start a thread over there.
  • Like
Reactions: 1
Originally Posted by allthetime  /t/1517369/subwoofer-to-pair-with-powered-speakers#post_24345632
If you go to the DIY forum for speakers and subs you will be able to get a lot of knowledge help. There are a couple of options, Assemble yourself (AIY) or do it yourself (DIY). You can find some good packages that you can buy from Parts Express  that have everything you need to assemble a good powerful sub depending on what you want.
Originally Posted by allthetime  /t/1517369/subwoofer-to-pair-with-powered-speakers#post_24345663
Thanks for your help :)
No problem, sorry I could not offer more specific advice, but I think this will get you pointed in the right direction.  You can probably accomplish a lot in the $500 range.
No problem.
Just out of curiosity... What prices/products would I be looking at if I wanted to purchase something ready-made that could fulfill my requirements? I doubt I'll be able to afford it, but I am curious about specs/options.
My guess of a reasonable starting point would the a PSA XS30 for $1150, although you would still need a room that would give a lot of gain in order to get much output at 10Hz.  Its a dual 15" design.
Go to Data-Bass.com   It lists a lot of DIY designs, such as the Dayton RS18-HO, $400 build cost, 87dB output at 10Hz.
  • Like
Reactions: 1
I dont think you can build anything that will do 10hz with authority for 500.00 let alone purchase a turnkey sub. You are looking at 3000.00 to buy a sub that will do 10hz with authority. You can probably build 4 SI 18" sealed subs for 1200.00-1500.00 that will get you decent output down that low. 1 single will not get the job done unless your room is the size of a closet. It takes alot of excursion and power to get solid output in that range in most rooms.
If anyone's still interested in this issue... this thread was very informative.
1 - 17 of 17 Posts
