1 - 7 of 7 Posts
Hello, I'm planning to purchase a new 7.1 or 7.2 A/V receiver under $800, I've been looking at these and they all seem decent:
- Pioneer VSX-33/SC-35
- Onkyo TX-NR609
- Marantz SR5006
Which one of these would be the best replacement receiver?
Any others I should consider?
thanks!
Premium Member
If you use Audyssey then you can scrap the 609 as it uses a much lower version 2EQ and rather consider the 809 instead which has been on weekend sale at Newegg at below your budget. The 6005 uses the same MultEQ XT as does the 3808. What about the Denon 3311CI or 3312CI both of which also use MultEQ XT? Also, Costco has the SC-35 on sale now as well just under your budget. Depends on whether you want to make a switch from Audyssey to MCAAC. You also might want to try to get a Denon 4310CI on clearance as it was the successor to the 3808CI.
Discussion Starter · #3 ·
thanks for the reply...
I'm done with denon, but I do like the Audyssey setup...
still looking at:
Marantz SR5006
Onkyo NR709
Pioneer VSX 33/SC 35
anyone else care to chime in?
I think you meant the Marantz 5006 instead of the 6005. The 6005 has MultEQ but no XT.
Originally Posted by kyle454
should I pull the trigger on an open box SC-35 for under $700?
That's a great price on an incredible receiver. If it's coming with a full warranty, I wouldn't hesitate!
Discussion Starter · #7 ·
I was able to get it for $677 shipped w/FULL 2yr warranty!
I'm stoked!
1 - 7 of 7 Posts
