Hello audiophiles,
I need your expertise suggestion about building a DIY subwoofer for my movie room sized 17ft*12ft. I am currently having BIC Acoustech PL200 subwoofer and it does a great job for this sized room. However after listening to SVS PB2000 i felt the bass from svs is much cleaner compared to PL200. The reason i do not wanted to have svs pb2000 is that the subwoofer box is too large and aesthetically not appealing for that sized movie room. Hence i decided to build a DIY subwoofer by myself which looks smaller in size yet producing a cleaner/deeper and heavy bass for my movie room. I do not have a large budget but yet i can go upto $500 including all (plate amplifier + subwoofer + MDF board + misc items to build). So i got 2 options right now.
Option 1) Use the existing subwoofer box and plate amplifier from BIC PL200. Just replace with a new subwoofer driver(as per your subwoofer driver suggestion) in place. This is more of a budget option.
Option 2) Build a new subwoofer MDF box with front ported design (similar to klipsch reference R-112SW) + Any subwoofer plate (as per your suggestion) + Any 12 inch subwoofer driver(as per your suggestion) which can provide more cleaner/deeper and powerful bass.
Kindly suggest me which option would be a better go for me.
Additionally also pls suggest me what is important to produce a cleaner bass ? .. Is it the subwoofer driver or amplifier plate or both ??
Waiting for your valuable suggestion. Please help me.
current subwoofer : https://www.amazon.com/Bic-Acoustec...d=1610477864&sprefix=bic+pl200,aps,151&sr=8-2
lucky
lucky
