I usually suggest setting some performance goals before you start shopping.
1)how loud do you listen to DVD/LDs(at/near reference levels?)
2)how big is the listening room?
3)how low do you want the subwoofer to be able to rerpodcue bass loudly/cleanly?
a lot of good subs produce verl loud/clean bass...but only >30hz. If you want 25hz extension..your options get a little limited...if you want 20hz extension...your choices are few....if you want <20hz...loudly and cleanly...there's a very short list...
some of the better *budget* subs right now include the mission 700,and the HSU VTF-2.
TV
TV
