I need some component suggestions (primarily motherboard) for my situation described below:
I'm building an HTPC for playback on a small CRT TV, but I'm planning on getting a new HDTV in the next 5 months.
The TV can only do regular NTSC, but has composite/SVideo/component inputs. Because of other devices hooked up, I'll be forced to connect via either S-video or component. I have an old 5.1 receiver that will decode DD/DTS over coax or optical SPDIF, so I'd like to send the audio to that (although I'll only be doing 2.1 right now) digitally.
When I get the new HDTV, I only want to connect to it via an HDMI cable. I'd like audio to be handled by the receiver still. I'm thinking about rearranging things and getting a newer HDMI capable receiver so that I can do surround sound and convert analog devices (like the Wii) to go over the HDMI to the TV.
Ideally the motherboard would support S-video and have an HDMI or DVI connector to use later. There seems to be some issues with audio over HDMI, so I'm willing to wait to have all of that ironed out and switch to a different HDMI video/audio card later. If so, I'll need an probably two PCIe slots on the motherboard. I've had much more luck using video card offloading for playing back 1080p h.264 content than just using a CPU, so I'd like that if possible starting off.
I'd like to be running Windows Vista on it because the graphics scaling options (for making text big) is better, but I have an extra XP license I might use instead to keep costs down. I don't currently have any preference for playback software like MPC, PDVD, TMT, etc.
Harddrive shouldn't be a big deal as I want to primarily store stuff over the network. I will run a Cat5 cable, but for the short term I have a wireless ethernet bridge that I can use so I don't need any sort of WiFi built in.
If anyone has a suggestion for a card reader that fits in a 3.5" drive bay that only shows up as a single drive letter, I'd also be very interested in that.
