I have a Lexicon DC-2, and have diffusers and bass traps set up as well as the room allows. I have a SPL meter from Radio Shack, and use the Lexicon pink noise to even the speaker sound levels.
My speakers are set where they have to be due to room constraints, and they can't be moved. However, they don't sound bad now...I'm just trying to tweak the system.
What I want to do now is EQ each speaker. I understand I can get test tones from Avia (which I will buy if needed) and perhaps from AV Essentials (which I have now, but have never used).
I have an Audio Control Bijou, a 6 band EQ (5 + sub) for HT. Its a high quality unit (ie. expensive but well thought of by the mags that reviewed it), specifically designed for HT.
In the past, I had a local audio engineer come out, but I'd like to do it myself, as he mainly does clubs, etc...and he's hard to get up with. And he did mainly what I describe below.
I think the process goes like this for each channel/speaker, but advise me...
1- first get the SPL equal for all speakers in full range, then...
2- have avia send the proper tone for each band the EQ can do.
3- adjust the EQ slide controls so the SPL meter has a constant level for each tone.
Am I right in assuming that even though I only EQ for a specific tone, the EQ also relatively adjusts for tones close to it both higher and lower (ie toward the next band the EQ can adjust)?
Also, do you EQ first, then adjust levels...or the other way around? Or do you go back and forth doing each repeatedly until its right.
Its been a few years, but if I remember, there are certain ranges that are way off, but if I EQ them as well as I can, I'm still better than if I didn't, correct?
Again, I'm not looking for perfection, and have searched the forum, read tons, and just want to improve on what I have.
