Is it possible for a power surge to damage the digital tuner in my JVC 52G887 HD-ila? A few days ago i went and bought a new amplified antenna it seemed to work pretty well. Then I turn my TV on one day and I can't get anything on the digital tuner. No HD, no digital channels, nothing (Except for the box that says "No Program"). The analog over the air and every other device I have connected still work as usual.
Just to make sure it wasn't the new antenna, I hooked up my old rabbit ears that i used before i bought the amplified antenna and the same result (No digital or HD and analog works fine). The only thing I can think of is that the digital tuner itself is damaged maybe by a power surge if this is even possible. Any help would be appreciated. Thanks.
