Status
Not open for further replies.
1 - 5 of 5 Posts
I have a dedicated 20 amp circuit for all of my components. My rack is plugged into one outlet and my projector is on another due to the distance between the rack and the ceiling mount. I was wondering if anyone has tried using a curcuit breaker / surge protector combo? Square D makes one that is compatible with my sub-panel. My biggest worry living in the South on top of a hill is lightning strikes. Would it provide enough protection.
Here's a link to what I am referring to:
http://www.squared.com/us/squared/co...56A3A007091D7/ $file/productsa2zFrameset.htm
Can you try posting a working link again, please?
Discussion Starter · #3 ·
Here's the description.
SURGEBREAKER® Secondary Surge Arresters
For branch panel protection. Specifically designed for QO or HOMELINE load centers, these SPDs easily plug into place for a secure fit, providing surge protection up to 40,000 amps. Single phase, 120/240. QO will work with NQOD panels.
Suitable for use in service entrance locations
Meets requirements of NEC Article 280
UL and cUL Listed for both QO and HOMELINE formats
UL 1449, 2nd edition Listed transient voltage surge suppressor
Meets ANSI/IEEE C62.11-1987
QO format used for QO load centers, combination service entrance devices and NQOD panelboards
HOMELINE format used for HOMELINE load centers, combination service entrance devices
LED indicator shows operational status of the unit
No surge protector that I have heard of will protect your house circuitry against a direct lightning strike.
Dave, I found them on the Square-D site. They do indeed plug into a panel, but they're not breakers. They plug in an unused 2-space-wide slot, and are whole-house protectors. I thought you were looking for a breaker that provides extra protection for an indiviuit.
Bryant/Hubbel and Leviton have receptacles with built-in surge protection. That may be more suitable for our uses.
1 - 5 of 5 Posts
Status
