Surround and Rear Recommendations for Monoprice Monolith in wall LCR
1359 Views 5 Replies 4 Participants Last post by  clipghost
I am waffling a bit between the Monoprice Alpha (3-way) in wall and the Monoprice Amber in-walls with the ribbon tweeter. I also would love everyone's take on 6" or 8" models.
I assume the 6" would handle everything just fine, but there's a negligible price difference and bigger is always better, right?!
(BTW, I have 2 pairs of Klipsch KHC-6 installed for my Atmos height channels ...
Thanks, everybody.
1 - 6 of 6 Posts
Anyone have an idea? I've managed to reach max analysis paralysis. I'm between these three ...
Monoprice Amber In-Wall Speaker 6.5-inch 3-way - Monoprice Amber In-Wall Speaker 6.5-inch 3-way Carbon Fiber Column with Ribbon Tweeter (each) - Monoprice.com
Monoprice Alpha In-Wall Speakers 8in Carbon Fiber 3-Way (pair) Monoprice Alpha In-Wall Speakers 6.5in Carbon Fiber 3-Way (pair) - Monoprice.com
Monoprice Amber In-Wall Speakers 8-inch 2-way Carbon Fiber with Ribbon Tweeter (pair) Monoprice Amber In-Wall Speakers 8-inch 2-way Carbon Fiber with Ribbon Tweeter (pair) - Monoprice.com
I have the two way versions of the 6.5" and 8" as well 6.5" in ceiling Alphas. I have been very satisfied with mine and the 8" versions have respectable bass output as well. I did have the Caliber 3 way 8" but the Alpha's sounded much better to me.
  • Like
Reactions: 1
If your LCR is going to be vertically aligned, I'd get three of the Amber 8" 2-ways.
If your not and your center speaker has to be horizontal, I'd get the Amber 8" 2-ways for L/R and the Amber 3-way for the center position.
If you want to save some money on the surrounds, I'd get these:
Apoligies for not being clear, I am planning 3 of the Monolith LCRs for my L, C, &R channels. Monolith by Monoprice THX-LCR THX Ultra Certified 3-Way LCR In-Wall Speaker - Monoprice.com All aligned behind an AT screen ...
Hope that makes sense.
  • Like
Reactions: 1
What did you end up going with for your setup completely? Especially the surrounds? Thanks so much!
1 - 6 of 6 Posts
