THX is considered post-processing because it is applied on top of standard decoding and processing modes. For example: after (post) your receiver processes a 2-channel source using PLII or decodes a Dolby Digital 5.1 bitstream, you then have the option to apply THX enhancements such as Re-EQ, Timbre Matching, Adaptive Decorrelation, etc. There are plenty of people that like what THX post-processing does for the sound and others (like myself) that never use it. Since you have the feature, push the THX button and see if you like the results (you won't hurt anything by trying it out).
I would leave MCACC on for room equalization purposes, but I would change the crossovers to better match the frequency response of the speakers. Check the manufacturer's specs for your speakers and set the crossovers slightly higher. This way, bass that the speakers can't reproduce will be re-routed to the subwoofer. The way you have it now (set to Large), your speakers are getting a full range signal (and they're definitely not full range speakers).
It shouldn't. The THX button should only engage the post-processing. Your speakers' crossovers are controlled separately, by the receiver's bass managment system. Turning surround processing On or Off shouldn't have an effect on the speaker settings.
Yes. When you see 2-channel material that is labeled 'Dolby Surround' it means that the original 4 channels (Left, Right, Centre, Surround) were folded down to 2 channels using Dolby Surround encoding. You have the option to listen to this material with 2 speakers or use matrix decoding (PLII, Neo:6) to turn it back into surround sound.
BTW, congrats on the taking the plunge. Glad it was worth it.
Best,
Sanjay
Originally posted by bldxyz What is the difference between the THX setting and the Standard Surround Sound settings? |
Also, I should note that, using MCACC, I have the speakers all set to Large, and then I manually adjusted to LFE->Plus (liked getting more bass in music that way!). |
Does the THX button just override the Large-Plus setting and use Small-Yes and 80 Hz for crossover? |
I read that Dolby Surround is just 2.0 content, but isn't there more to it that stereo? |
Best,
Sanjay
