1 - 1 of 1 Posts
I have a large room, that is kind of a great room. Its living area, kitchen and dining in one large room Id say 45x40 or so. I have a dedicated HT room with projector, but in the last few years, we have been watching lots of movies in the large room, because we got a new couch, and my projector is only 720p. I have 2 large PA speakers for my large room set up. they are 12 inch woofers and horns. driven by a newer Denon s700w that I just bought. I have a center with the 2 PA speakers for movies. Question is, if your were going to put in surround speakers, how would you do it? 4 options. There is a bar that is head height when sitting on the couch behind the couch. The counter is 33 inches high, so kinda low. Should I mount bookshelf , or just smaller rears under the counter? Cabling is going to be toughest here. Will prob end up being an 60 foot run. I have to go up and over, and I have a concrete floor. Option #2 /3, is mounting speakers in the ceiling.. either flush mount, or bracket hanging. Ceiling is 9 feet high. would mount about 5 feet back from the couch. (same distance as the bar) option 4 is getting some bookshelf speakers, and placing them on top of kitchen cabinets, but all the way in the back of the room. (20 feet from couch) I have not bought any speakers yet. but I don't want to spend more than $300 on the set. Also, if I got those pa speakers off the floor by a couple of feet, would that help my overall sound? thinking of building mdf stands. Are there any wireless surround speakers that are any good? (for counter option) (see photos below)
1 - 1 of 1 Posts
