I would not put them on the back wall at all. Mount one above the door on the left side and the other on the right wall directly across from, and at the same height as, the left side. The surround sound speakers should be at your sides, not behind you. See the Dolby website:
http://www.dolby.com/consumer/home_e...oomlayout.html
Be sure to set the speaker distances in your receiver and calibrate the levels with an SPl meter.
Craig
Craig
