Can you and others please help me understand more about high efficiency speakers vs the Infinities? Andrew Robinson in the comments of his Infinity Reference Series review, responding to someone asking whether they should get the Infinity's or the "Tekton design speakers," which he also references as "lores," wrote this:
And also he said:
Easy fluid sound, that also more "comes alive," sounds like the best of both worlds. So does sound that feels more in the room with you, and less like there are electronics in front of you. Who would want the second over the first? And shouldn't surround sound sound "alive" not just like a static studio recording? "Alive" sound can still be "accurate."
I didn't realize how big the Infinity's were when I bought them. Do I really need that much power in my 9x9x8.5 viewing area? Yes on one side it's totally open to a 26x13x9.5 room, but the speakers will be pointing at me only 8-10 feet away, not to the side. Are there smaller "high efficiency" speakers that will still get my room as loud as I want it and more, and not get overpowered by a sub, but sound better than the Infinity's? Im worried I will only be able to turn the Infinity's up to 10% of their total volume, and that they wont sound good that way. Or is it possible to turn them up as much as necessary to get the best sound out of them, but still control the volume in my room however I want just by keeping the audio output from the receiver down, but the Infinity's volume dial up?
Or does it not matter how far you turn the Infinity volume dial up, they will not sound their best unless they are outputing high volume no matter which way you do it? When I asked for the best surround sound speaker recs in my price range, no one even mentioned high efficiency options, or any other options besides "you need a center, two towers, and back speakers." No one told me there were other options, no one really discussed size even when I asked, etc. That is what is frustrating. Leaving out key information, often providing false or misleading information in terms of the information that was given, pressuring to buy, false deadlines, potentially steering to certain products over others, etc.
I really would appreciate more help to figure this out and get it done in the next few days. I might actually just have to send everything back ASAP during the return window if I cant find reliable info before then to feel I made the right purchase, or get something else.
