Status
Not open for further replies.
1 - 8 of 8 Posts
When I stopped by a Costco store I finally saw the SVA plasma that you guy mentioned a few weeks back. I took the liberty in buying one and this is what I found with the unit:
1. Tried hooking up may Panasonic Progressive Scan dvd player to the unit, no matter what I tried I only got 480i. I borrowed my friend's Sony Progressive scan and again 480i only. I tried connecting my Samsung HDTV Set-top box and nada no signal.
2. RGB is the only input that can accept HDTV feed, when I hooked up my Samsung SIR-TS165, I was not able to adjust the vertical size and the image was half on the screen and half off. So what happens when you want to use Component or DVI to watch HDTV programming? Guess your out of luck with this unit.
3. Don't think it is consumer compliant, did not see a FCC Class B sticker on the panel so it's likely has not been tested therefore it likely is not compliant with FCC regulations.
Seriously did the manufacturer just product this product overnight and put false advertising to mislead consumers? I'm seriously disappointed with this product, not only is it going back to Costco, I'm gonna let Costco management know that I cannot believe they carry this worthless brand.
Let me know if any of you guys experienced with the SVA junk.
According to the specs here:
http://www.costco.com/product.asp?ca...4&log=&navtop=
The unit is only listed as supporting 1080i and NTSC, not 480p nor 720p.
This is Hilarious:
"There is only two words to describe the New SVA Plasma " High-End".
The 42-inch (HD4208TIII-PDP) HD Plasma TV combines stylish design with the excitement of HDTV compatibility (1080i). "
I "Like" the way they describe the Plasma to make people believe it's a HD set.
____________________________________
That's why SVA stands for Sh*&ty Video from Asia!!
J
1 - 8 of 8 Posts
Status
