Your Sony AVR lacks a 3.5mm 12V trigger output?
(The SVS SB-1000 Pro has one.)
What is a trigger? Don’t subs turn themselves onCorrect, it's a DH590. #meh
Paul
I don't know about the PSW-505, but Hsu Research claims that if you turn one of their subs on but with no input signal, that the power draw is about the same as in standby mode (sleeping, waiting for an input to activate it). Apparently the switching mode amps dissipate very little power when no input signal is present.My Polk PSW-505 has an auto setting, but it doesn't work unless you crank up the volume to a certain level, let it activate, then turn the volume back down...it's annoying.
Paul
The "Auto" feature on a sub means the sub is always on but in standby mode, and signal / lack of signal from the AVR causes the sub to switch out of / back into standby mode.What is a trigger? Don’t subs turn themselves on
