Status
Not open for further replies.
1 - 8 of 8 Posts
· Registered
I upgraded a unit with a 250 gig drive, which i got cheap, and i know now that it was cheap because it is noisy, I can hear clicking, even faster clicking when I fast forward. I also have another upgraded unit with a quiet drive. The unit with the quiet drive had the noisy fan, and the one with the loud drive has a quiet fan. Would I be able to swap the drives between the units? I want to put the noisy one out of the bedroom to keep it quiet for sleeping.
· Registered
They'll both complain about needing to check for activation before you can do anything else with them. Remember you're also switching identities, IVS names and anything else associated with them (except the ReplayTV serial number and ISN).
· Registered
Maybe someone who has done this more recently can comment. My
recollection was when swapping drives, it didn't complain about activation,
only when copying the image onto a different drive did it complain (which
gets fixed after net connect). I could be remembering wrong. Most folks
copy the image onto a new drive so they wouldn't be able to comment.
· Registered
I'm pretty sure it will nag you about activation when you swap drives. Doesn't really matter since it's easily fixed with a net connect.
· Registered
Would it be less work to just swap the fans?
· Registered
This wouldn't work. Assuming one is quieter because it is in a newer 50xx, the fans themselves are actually the same. The newer 50xx models just had a motherboard revision that permit the software to control fan speed by varying the voltage provided to the fan.
· Registered
[Gilda Radner]
"never mind"
[/Gilda Radner]
:rolleyes:
1 - 8 of 8 Posts
Status
