Which sweet spot do you think is more important - the audio or the visual?
I am thinking of putting in a floor mounted CRT. I have the option of making the audio sweet spot in the second row, behind the projector. The problem is the viewing angle is only 24 degrees, way below SMPTE or THX standards.
The alternative is making the projector the sweet spot and sitting next to it. This moves the viewing angle to about 33 degrees, but the seat is not in the audio sweet spot.
Which would you choose?
Skip
Skip
