1 - 3 of 3 Posts
We recently purchased a used LT37HVS. The owners were running it off an antenna. When we hooked it to our cable (Not the main set with the cable box) it has 3 channles that are locked. We have tried everything in the manual and nothing removesw the lock. My husband would rather give it back but I wanted to see if there is a solution. So if anyone knows how to unlock it I would appreciate the help.
Are the channels "skipped" or "blocked"? If the channels are skipped you should be able to access them by inputting the channel number directly. If the channels are "blocked", yoiu have to go into the SETUP, then PARENTAL CONTROL, then CHANNEL BLOCK. Uncheck the blocked channels and you should be okay.
1 - 3 of 3 Posts
