I have 2 fans in my HTPC. The CPU fan and a system/case fan blowing air out the rear of the case. Both are connected to 4 pin headers on my motherboard which is an Intel DH67CF.
The system fan is a Noctua 4-pin PWM.
I've been using the Bios to control both fans. Up until now fans have been running great. The bios has been increasing the fan speed based on temperature and for the most part both have been spinning at a fairly low RPMs as the component temps have been running in a nice temperature range.
This morning I noticed my system fan was running very fast/high rpms. Nothing out of the ordinary temperature wise as shown in the Intel Desktop Utility. Approximately the same temps as always. That has happened once or twice before and a reboot will fix it and get it back to normal. Not this time. After every reboot the fan stays spinning a high rpms. I've gone back into the Bios and played around with the fan settings, gone from automatic to manual and back, changed back to defaults but the fan continues to spin at a high rate at every reboot.
The CPU fan is still running at a lower speed and the Bios is managing it just as before. Just not the system fan.
So do I have a bad header now or has my fan gone bad? Or any other ideas on what it could be and how to troubleshoot and fix it?
