My select button stopped working, so I was going to pull the remote apart and fix it with a window defogger kit (as suggested in the past). I did a quick check of the faq, and under the question of "If I change the batteries on my remote, will I lose all my codes?" the answer is "No. Just be careful not to press a key on the remote while the batteries are out."
What? I have to pull the batteries out to split the remote, and given the tight fit of the thing, how on earth am I going to make sure I don't press any buttons? How important is this? I've got it fairly customized with swapped buttons and volume punch throughs and all that, and would be really bummed if I had to do all that again...
Any advice on how to safely split the remote without touching any buttons? Are there any buttons in particular to avoid?
thanks,
david.
thanks,
david.
