Using the Santa Cruz's digital out with a mono 1/8 to RCA plug to a h/k avr-520 coax. If I use WinDvd with settings to use SPDIF, I get no sound, or at best if I change the settings(I forget which ones, I'm at work)I get 2.0 only from DD/DTS sources. If I use PowerDVD I only get white noise.
Any clues why the signal isn't being passed correctly? I've read of similar scenarios's in other threads but the solution usually has to do with changing the settings in Audio HQ which applies to SB cards.
Anyone with a Santa Cruz that can lend a hand?
