1 - 20 of 315 Posts
Well I finally got around to actually cutting some panels in between trying to get the theater finished up for a family get together end of this month.
Here are the details:
Cabs are 17.25" W x 36.5" H x 13" D (not including 2nd baffle). There will be an internal divider bringing the total height down to 31.5". I did this as I preferred a single tower as opposed to putting them on stands. This will also allow me a separate place to mount the xovers. Internal volume should come in at approximately 2.90 cubic feet. This isn't finalized and can be added to or removed depending on how I shift around the divider.
Power will be provided by some form of external amplification. I decided to go with 4 ohm at the last minute to match the dual TD6 height arrangement, so I'm pretty sure the 3009 won't love me if I push the volume when feeding a full wall of 4ohm speakers. I'm leaning towards either a used Parasound Halo or Outlaw Audio for sale. I feel either will provide enough juice to do the deed.
Xover will be provided by none other than Matt. I really can't express enough appreciation to that guy for answering endless questions and taking time out of his day to do the testing and building to make this build a reality. I also want to thank John, Jake, and Erich for being instrumental in the build, buys, and logistics for also making this come together. This is a great family here in the DIY forum.
Before getting on to the build, which isn't very exciting at the moment, lol, here is the current progress on the theater. I snagged Carps other SMS1 so I'm currently in the process of setting up the SI's for a true stereo setup taking advantage of my 3009's dual sub EQ feature.
I apologize in advance for the crappy pics. Too lazy to dig out the DSLR so you get my cheap point and shoot.
Screen wall coming together. Finished wrapping the upper and lower panels in GOM. Just need to finish up the side panels. Screen frame is done. I've been waiting to stretch the fabric until I'm done as it's easier to pull the screen on and off without the material. Makes it a one man job as opposed to two.
I said I wouldn't mount the projector on this build (unlike the last one), until it was finished. It's still boxed up. Just finishing up the hushbox and mocking up cutouts for the 2.35 lens.
Little side angle to show columns. The space I had to work with was less than optimal (128" wide), so I wanted to keep the acoustic panels as narrow as possible. I even decided to flush mount the surrounds and rears into them to save as much space as I could.
Lower shot with lighting and trim work.
Oh yeah, the obligatory cab shot. Exciting, isn't it.
Discussion Starter · #7 ·
Originally Posted by countryWV  /t/1470958/td15m-seos12-bms4550-build-theater-progress/0_80#post_23269833
That room is sweet!! Your build is going to be exciting to watch.
Good Luck
Chris W
Thanks Chris. Not nearly as nice as some of the big dogs, but it's all I had to work with. Everything was done by me and me alone, except for the carpet (and probably the screen stretching).
Originally Posted by Sibuna  /t/1470958/td15m-seos12-bms4550-build-theater-progress/0_80#post_23269949
interesting, what are you planning on tuning the boxes to?
Boxes will be sealed and crossed over to subs at 80hz.
Originally Posted by tuxedocivic  /t/1470958/td15m-seos12-bms4550-build-theater-progress/0_80#post_23270157
Very nice. I think you're going to love the upgrade!
I will be sorely disappointed if I don't get this
Originally Posted by bhazard  /t/1470958/td15m-seos12-bms4550-build-theater-progress/0_80#post_23270214
Interested in this build. I'm guessing you're creating your own baffle?
Yup.
Originally Posted by rajacat  /t/1470958/td15m-seos12-bms4550-build-theater-progress/0_80#post_23270461
Are you going to double up the thickness on the baffle?
Yes. Front baffle will be two 3/4" MDF panels.
Discussion Starter · #12 ·
Originally Posted by Gorilla83  /t/1470958/td15m-seos12-bms4550-build-theater-progress/0_80#post_23271520
Nice man, should work out really well. You're in good hands with Matt doing the xover work.
Yup. I must trust him implicitly as OCD as I am.
Seeing what he was able to do with the B&C/360 combo, this should be a home run.
Banned
I am just curious as to why a lot of you guys are running these expensive 15" woofers with an 80hz crossover? Isn't this limiting those large woofers in their ability? Couldnt you get a cheaper 10" or 12" driver to cover the same range? (not knocking this, just curious). Those AE drivers are pretty pricey, so why not go with something from the likes of JBL or Dayton? Do those AE woofers really excell that much more than the cheaper drivers from JBL, B&C, Dayton, ect..?
Discussion Starter · #14 ·
Originally Posted by Martycool007  /t/1470958/td15m-seos12-bms4550-build-theater-progress/0_80#post_23272135
Valid question.
I spoke in depth with John about the TD10, 12, and 15. According to John, the TD15 was the best behaved driver out of the lineup. It also has the ability to play louder, with less distortion. After much research, I believe it was the right choice. I looked heavily at the B&C driver, but with the GB pricing, it really didn't cost a lot more to go with the AE. I also like supporting a USA company.
I'm sure Matt, Tuxedo, and the likes, will give you an in depth breakdown with charts and graphs, so hold tight.
Originally Posted by Martycool007  /t/1470958/td15m-seos12-bms4550-build-theater-progress#post_23272135
I'm actually making mine full range capable when called upon with the 12X version. It'll run in double bass most of the time, with 2 SI 18's in the mix. The M versions have less xmax, so it doesn't make sense to dig them down as low.
I would have gone with the 15X, but the width is a bit too much for me, and there wasn't a crossover for it and the SEOS. The GB pricing made it much more enticing to use an AE woofer for about $20 more than a comparable B&C. I think it will have a distinct advantage in SQ, along with more power handling. We'll know soon enough. I have SEOS 15s on pre-order, so maybe one day i'll mimic this build with them.
I'm interested in how the SEOS / TD15M / BMS4550 blend comes together as a whole. Could be epic. Hasn't been done here yet.
Marty,
In order of importance IMO.
Big woofer:
Narrower directivity there's less sidewall reflections lower in frequency.
Higher sensitivity, usually.
Lower distortion.
Can actually play 80hz very easily. I'm big into 8" and 10" designs. It's what I like. But they do struggle to get good output even at 80hz. The 15" has the Sd to do it without issue. This is always a battle with sensitivity.
Small woofer:
Cheaper.
Higher frequency usability (The 15" AE has shown problems above 1khz: http://www.diyaudio.com/forums/multi-way/205875-has-anyone-here-measured-td15m-i-have-them.html ).
Smaller cab requierments.
Closer center to center driver spacing.
Discussion Starter · #17 ·
Well Matt is slaving away building some test enclosures for modeling. Once he finalizes dimensions, I'll start working on these cabs as well. Too many irons in the fire what???
Looking sweet. Why use a .22 when you can use a 50 cal.
Notice how much a perfectionist Matt is. Even with the test enclosure all the drivers are lined up perfectly.
Discussion Starter · #19 ·
Originally Posted by Sibuna  /t/1470958/td15m-seos12-bms4550-theater-progress-dual-td6m-seos12-bms4550-build-d/0_80#post_23272593
i like how that looks small yet i know its huge
Yup. Especially for a height.
Preliminary dimension are 14.5" w x 15.5"h x 7.5" d, 3/4" baffle and 1/2" for the rest.
Banned
Originally Posted by tuxedocivic  /t/1470958/td15m-seos12-bms4550-theater-progress-dual-td6m-seos12-bms4550-build-d#post_23272365
Marty,
Big woofer:
Lower distortion.
Small woofer:
Cheaper.
That makes sence. So with regards to crossover design, I understand that the drivers need to be fairly similar with regards to sensitivity,
otherwise you will have to add other things to the crossover, like say...an Lpad for a tweeter....right?
I just can't seem to wrap my head around the idea that a 15" driver is all that necessary when crossing over at 80hz. I used to own some
store bought speakers back before I got into DIY, and they had 6.5" mids in a 2-way configuration and could reach down to 50hz no problem.
Actualy, I have heard lots of big box speakers that could reach down that low with much smaller drivers.
It just seems like having an expensive 15"
driver is not actually necessary unless you want to run the speakers down to...say....20hz or 30hz. I do understand that using a 15" over say an 8" or
10" is going to have less distortion, but are the distortion differences all that audible?
1 - 20 of 315 Posts
