You just need a fairly simple modification installed inside the receiver to grab decrypted MPEG2TS before it reaches the decoder chip.
Its silly simple to design and make, however, illegal to sell or advertise, on machines with "legal" 1394 outputs. This is why R5000HD is installed only in receivers without a 'copy protected' digital output.
This way lets you capture 'live' and is probably not what you want, but probably is the easiest thing to do and maintain.
Or you can buy Windows Vista, ATI's now-in-development cablecard-enabled capture card, and record DRM'd files.
You won't find a "legal" solution to do what you want, easily, AND without DRM. Not these days, anyway.
Encryption-wise, I think its DES for the audio/video payload scramble.
