Status
Not open for further replies.
1 - 4 of 4 Posts
For Marqee 9500LC upgrade, I am going to change mini RCA cable from VIM bord to neck board with new cable.
My friend and I baught mini RCA plug ( 1000 units we had to buy).
myfriend changed exsting cale with tefron shield siver wire.
But we can't see any improvement in PQ.
Any suggestion?
what is original cable material?
some one said shiled silver wire is best.
what kind of silver wire is best?
We used cable which has core made with 15 very fine silver wire.
Jaehong,
The improvement will be subtle at best. Actually, the wire change Mike recommended in the maintenance thread was for an improved ground path between VIM and neck boards, not so much the PQ.
I'm quite sure you would not notice any difference with DVD as a source, even with best HTPC and MP-1. But you might with a very clean HD source, a very well aligned projector, and Mike's VIM and neckboard mods (not the ones in the maintenance thread).
The Commscope cable that I referenced in the link RobertV gave you is the best substitute as far as I know.
--Bill
1 - 4 of 4 Posts
Status
