About to pre-wire a new system. Having never doen this, I have made a few threads and got the basics and have found out that basic wiring does not matter much to an extent. With that, I will probably go with 12 or 14 AWG wiring. When routing cables behind walls, should I terminate with banana style plugs, or pass through wall plates? even if that, should I use terminating ends such as banana plugs, or just screw down connection? I am skilled with a solder iron, and can have soldered down to 40 AWG reliably. I should I try and find some solder style banana plugs, or screw down ends? Everything I see is usually 90 degree ends. I am simply lost at where I should do my shopping and what I should be shopping for. I have a small budget, but I don't want my budget to get in the way, so I am not opposed to saving some more for quality connections. Currently I have some decent discounts at Amazon for various resons, along with free shipping for being a prime member, so this may be my preferred shopping route as it is generally much cheaper for me after discounts have been applied. Can someone direct me and tell me what is gimmicky, and what is truly worth while such as screw in plugs, solder in, 24k gold plated, copper plated, zinc plated, etc? Links would be preferred.
